Old 13-02-2020   #1
Airbag wires
After replacing stalk switch I have a airbag warning light so looked behind the airbag again and realised I havnt plugged the yellow connector in, but I cant find out where to plug the yellow airbag wire to? Any idea on where the yellow connector connects to?, I've connected the green one to the airbag but no idea for the yellow
ID:	206452   Click image for larger version
Cerwyn is offline Reply With Quote Quote
Old 13-02-2020   #2
varesecrazy has donated!
Re: Airbag wires
Itll be the same for most FIATs
SEARCH should find panda info..
'Clockspring' should find the info
Old 13-02-2020   #3
Re: Airbag wires
I've just searched clockspring and looked in all the threads but cant find find an airbag with just the green connector it's always two connectors in the back of the airbag, I'm really stuck on what to do as theres no place for that yellow connector to plug into.
Old 13-02-2020   #4
Re: Airbag wires
did your old clock spring only have one airbag wire?
The two wire set up is for Dual stage airbags, this means that depending on the severity of the accident the airbag will inflate different amounts.
The airbag in your picture is only a single stage airbag so therefore does not have two connections.
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers can’t be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 13-02-2020   #5
Re: Airbag wires
I'm not sure if I have the old clock spring I'll try and find it but I'm pretty sure it had the 2 wires aswell the yellow and green, I've only seen how to change a steering wheel thread on this forum where he had the single stage airbag but had the 2 wires and he has no airbag warning light when putting it all back together, I'm honestly lost on what to do next really as the code cant be reset it wont go away
Old 13-02-2020   #6
Re: Airbag wires
As you can see below that guy that I followed for the tutorial also had 2 wires with the single stage airbag but he doesnt get an airbag warning light after assembling it all, and I'm sure I've installed it correctly as all my steering wheel buttons, horn, etc work
Name:	Screenshot_20200213-221738_Samsung Internet.jpg
Old 14-02-2020   #7
Re: Airbag wires
The airbag warning light won’t go away by plugging in the correct wire, you need to plug it in and clear the error, therefore you need to plug it in and see what the error is. If you didn’t disconnect the battery or you disturbed the wiring after refitting the battery this could be the problem, it could also be nothing to do with the airbag and might be a connection under one of the seats which can happen with moving seats forward and back.
You need to plug it in and see what the fault is and then try and clear it, you only have a problem if you can’t clear the fault on the ECU
Old 15-02-2020   #8
Re: Airbag wires
Yep I've had it scanned and got a code and it wouldnt clear so the problem is there I just dont know what to do next. Does this code help you in anyway?
(T) Airbag light on passenger airbag problem - Fiat Idea GRBASF Idea 6 06-04-2015 23:03
(T) Airbag light - wires for front crash sensor gording01 Grande Punto 2 23-09-2014 00:40
(T) Airbag wires under drivers seat Stilystilo Stilo 4 01-02-2011 22:27
(G) airbag light told wires snapped?? Brin Punto (Mk2/2b) 14 08-05-2010 22:34
(G) Soldering the airbag wires? pieandapint Stilo 20 20-05-2008 13:39
