Thread Tools
Old 09-11-2019   #1
Denmark
Oil replacement warning
I have recently bought a Fiat Punto Evo 2012-model. Just before delivery, the seller replaced oil and oil filter.
However, it seems like he didn't reset the oil replacement counter, cause the oil light has just started flashing.
I have tried resetting the counter with Multiecuscan, but haven't had any luck so far.
Will I damage the car if I just keep driving with the light flashing? I know that oil and filter has been replaced already, but somebody mentioned that it might not clean the particler filter, if the engine think it needs an oil change..
Rasmusbdk is offline Reply With Quote Quote
Old 09-11-2019   #2
varesecrazy has donated!
Quote Originally Posted by Rasmusbdk View Post
Is it a diesel?
There are several things to reset with a DPF equipped diesel
Old 09-11-2019   #3
Denmark
Quote Originally Posted by varesecrazy View Post
Is it a diesel?
Yes its a diesel. I have an OBD that works very well with the car through torque on android. However, i Havent suceeded in connecting the device to multiecuscan on Windows. Program finds device, i just cant get it to connect.
Problem might just be that i have no idea what to choose as 'control module' in the program. Think i have tried them all though..
Can i look it up with vin number?
Old 09-11-2019   #4
Re: Oil replacement warning
Hi.
Ok.
In MES you have the :
Oil degradation
Service indicator
Dpf regen counter - % marker
The basic ELM327 cable should be enough.. no coloured adaptors required :
Old 10-11-2019   #5
Denmark
Thanks. Thats not really the issue though. Problem is that i cant even connect to MES..
I made this thread about the issue:
http://forum.multiecuscan.net/viewtopic.php?f=5&t=7029
Anyway. My biggest concern is whether it Will damage the car if i dont get the warning reset. Any ideas about that? :-)
Old 4 Weeks Ago   #6
Elm cable into com port
F9 : settings
Scan for devices.. should tun through..and say ok
If that works.
Connect to car..with ignition on
SCAN - will list :
Engine
ABS
STEERING
Check the ECU specs then select these in the dropdown
Body. Engine. Ecu spec.
Then CONNECT
Old 4 Weeks Ago   #7
Denmark
F9 : settings
If that works.
SCAN - will list :
Engine
ABS
STEERING
Then CONNECT
Thanks. How do I know which ecu spec to choose? ☺️
Old 4 Weeks Ago   #8
The list of devices on the car that MES detects will show the relevant spec of YOUR CAR
Old 4 Weeks Ago   #9
Denmark
Thanks. Guess My obd isnt supported then. Any idea where i can get a cheap one that is?
Old 4 Weeks Ago   #10
I dont understand..?
I believe you have MES?
An ELM 327 cable ?
That is all you need
Old 4 Weeks Ago   #11
Denmark
An ELM 327 cable ?
I have a Bluetooth obd that ems wont find in scan. Need a cheap working cable
Thread Tools
(T) Low oil pressure warning light. Oil pump replacement? Marc Lewis Punto (Mk2/2b) 10 21-09-2019 22:50
(T) Battery replacement WARNING Andy Monty Punto Evo 0 23-03-2013 17:34
(G) oil pressure warning light on, oil level full tjo Punto (Mk2/2b) 7 31-01-2012 15:48
(T) Warning - Abarth Thermostat replacement! Andymacselespeed Stilo 15 05-03-2011 19:58
(T) Warning bulb replacement. Orfy Cinquecento / Seicento 1 22-11-2009 21:40
