J Jonboy1919 New member Joined Apr 4, 2021 Messages 8 Points 4 Apr 4, 2021 #1 Hi , I’ve got a rear wiper that doesn’t work when turned on , what could it be, I can’t find a fuse to it either. Thank you
O OldEngineer Member Written a guide Joined Apr 6, 2011 Messages 79 Points 69 May 11, 2021 #2 It will be water down the shaft causing it to seize. Common Alfa Fiat problem. See this... https://www.alfaowner.com/threads/solved-rear-wiper-seized.862546/
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,982 Points 7,836 Location Near the M4 May 11, 2021 #3 Halfway down this thread page https://www.fiatforum.com/marea/331556-boot-opening-locking-problems.html?331556=#post4043405 I had to do both of my marea weekends frozen spindles
G gredoeb New member Joined Jun 2, 2021 Messages 21 Points 3 Jun 10, 2021 #4 Check the motor if it is getting power.
