General 17 inch Punto 1.3 rims
Italoman
Good morning all
Owner of a reprogrammed stage 1 PUNTO 1.3 75, I recently got 17 OEM rims, know if I will have to change the studs on the 15 original rims or buy new ones
And if among you the owners who made this modification the results will be close to the original rendering or with a 4x4 effect
thank you in advance
the beautiful
the rims in question
Shouldn't be any problem with fitment, as you say they are OEM and the PCD wouldn't change.
I'd take a measurement of the outer diameter of new wheel+tyre and the original - If there's a difference it may affect your speedo.
If they are the same diameter, the car will not change it's 'stance' from the original.. you'd need lowering springs to properly make it look more 'sporty'.
Happy to be proved wrong as ever :)
Thank you for your feedback, of course I will respect the original 205 / 45R17 fit the original 185 / 65R15 fit
What about the studs?
if only it will have the same results :culte:
To start a big thank you for your advice :)
what puzzles me is that the height varies a lot between models of the same line
a little comparison
Should I change the front springs with a shorter OEM reference since on mine I find it raised just from the front
thank you !
First of all I would like to thank you for all your comments, and I share with you the final rendering of the modification
Do you think a lowering is required or is it fair?
Handling has improved greatly, but the feeling of the weight of the 17s is undoubtedly
What convinced me to review a more thorough reprog :diable:
They’re the same wheels I have in my Evo. I would leave the suspension alone, combined with the harder suspension on my sporting the ride can be quite harsh sometimes, also my sporting was designed for it, fitting lowering springs to your car may completely ruin the ride
Nice!
It is strange how different your side profile is to mine, with the same alloys fitted. I've got the 'Sporting' model and the front gap between wheel and arch is similar to your rear gap, while my rear is about double yours.
Thanks for the compliment :)
For the lowering I have in mind to apply quality springs like EIBACH for a total of -30mm front and rear for more visual homogeneity
@ h0sep1pe Yes very strange on the Punto, yours will surely be a 2-door, I think this is mainly due to the kind of bodywork 2 or (5 doors heavier spare wheel 15 ''…) for the rear suspension and the weight of the engine (mine is a 1.3) for the front
Your opinion on this article :
https://www.ebay.fr/itm/Eibach-Tief...434820?hash=item5b6c073204:g:rIQAAOSwCtFeLDGm
otherwise if you find that it is balanced I leave it as its :pouce:
