Tuning car radio aftermarket not working?
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
BravoCity
hi, i just purchased a pioneer car radio for "second hand". however i am experiencing some problem there is no power to the radio after fitting it.
when i remove the new radio and reinstall the old one "fiat punto radio" it works?
ive checked the fuse on the new radio and the fuse is fine.?
any ideas.
First thing I'd do is test the 'new' unit in another vehicle, just to be sure that it does actually work.
If it does, then it may be that the vehicle wiring needs some adjustment in order to correctly power the unit, this is usually accomplished through the use of a separate wiring harness. So it should be vehicle wiring -> wiring harness -> headunit connectors.
