Comment
Guide Tools
<!-- google_ad_section_start -->"Wiring A Punto Stereo To Ignition Using ISO" (yellow red wires) MK2 only not MK2b<!-- google_ad_section_end -->
Published by nik0
10-02-2009
Difficulty Level: 1
User Rated:
Difficulty Level: 1
So basically, if you have a Punto like mine (mine's a 51 reg with the 6 speakers+subwoofer system), you will have an ISO connector in two parts, a white part and a black part. The black one is for the speakers, the white one is for power + control signals.
On the top row of the white one, pin 3, is a green and blue wire. This is an ignition switched power connection (as shown in the Haynes manual, and which I confirmed by testing with a multimeter). It is wired through the 7.5A fuse F49 in the interior fusebox. Here is a pic showing the wire:
I connected this to the "switched power" input of the radio. Your colours may be different, but if it's like mine (Pioneer DEH-5000UB ... nice head unit by the way) then the connections are:
Car black (pin 8) --> Radio black (battery negative)
Car red+white (pin 4) --> Radio yellow (THIS IS THE PERMANENT POWER)
Car green+blue (pin 3) --> Radio red (THIS IS THE SWITCHED POWER)
To do this I used a paperclip to pop pin 7 (red wire) out of the ISO socket on the loom that came with the stereo, and poked it back in so as to magically become pin 3, before connecting it to the car. (So no modification to the car wiring was needed, which was nice.)
Here's a pic of the red wire ready to be poked back in to slot 3, to live in its new home above the yellow wire:
I was worried the 7.5A fuse might not be enough, so before I did all this I measured the current drawn by the head unit and it turned out it takes hardly any current from the switched wire anyway (my crappy 2.99 multimeter showed 0.00A, so less than 0.01A... ). Rather, all the current used to power the radio is drawn through the permanent connection. The switched connection seems just to be used as a signal line. This wasn't surprising, since the yellow wire on the loom is big and thick while the red one is quite thin at the head unit end. (All this might not be the case on other radios of course so I would advise checking for yourselfl!!)
So anyway, it's all working lovely, and I'm glad I didn't need to dismantle the steering column and splice the orange wire (although it would have been fun!) Hope this helps.
Thanks Mean Machinist, John87, AlanB6011, a1ant, OllyCz and 1 others thanked for this post
Likes TheBogieMan liked this post
Dislikes AlanB6011 disliked this post
Old 21-03-2009   #1
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
re: "Wiring A Punto Stereo To Ignition Using ISO" (yellow red wires) MK2 only not MK2b
This is awsome, works 100%. A lot easier than than wiring it to the cigarette lighter etc...
Top Job
smokeyjoe03 is offline Reply With Quote Quote
Old 18-05-2009   #2
I need to sort my connection out, i brought an alpine stereo for my 1996 M1 Punto and put all the wires together, but 2 months later my battery died, did a couple of tests and realised it was the stereo draining all the power when the car wasnt in use. atm i have to disconnect the ISO connector everytime i turn off the ignigtion, will this guide help me for my punto?
Jawdee C is offline Reply With Quote Quote
Old 21-05-2009   #3
Geek of the Week
Trader Rating: 1
yes and it works perfectly
Old 24-07-2009   #4
My problem is that turning the ignition off does not turn the radio off - bad news if you leave the radio on accidentally overnight.
Will this fix that? Why isnt the punto ISO connector done properly in the first place?
psychocandy is offline Reply With Quote Quote
Old 24-07-2009   #5
Confused. So what does the radio red (switched) connect to at the moment?
Old 25-07-2009   #6
Talking re: "Wiring A Punto Stereo To Ignition Using ISO" (yellow red wires) MK2 only not MK2b
Haha, i got my stereo connected straight to the battery and my amp connected to the rear lights ^^
Well, at least now i know there if the bass isn't working i probably didn't turn my lights on ^^
Thanks AlanB6011 thanked for this post
exom is offline Reply With Quote Quote
Old 14-10-2009   #7
Quote Originally Posted by psychocandy View Post
Will this fix that?
Yes.
I think because the factory radio is controlled separately (by CANBUS I think). It switches off 20 minutes or so after the ignition.
nik0 is offline Reply With Quote Quote
Old 17-12-2009   #8
Quote Originally Posted by exom View Post
hahahahah
TomSwindellMK3Punto is offline Reply With Quote Quote
Old 22-12-2009   #9
Quote Originally Posted by nik0 View Post
Yes.
Flippin annoying that they cant use the switched live properly. Number of times I've flattened the battery by leaving the radio on...
Old 03-01-2010   #10
Just a quick question:
I just tried this and i couldn't get the red wire out of the black ISO socket. How do you get this out? Wiggle a paperclip around or something?
Many thanks
imapctuk is offline Reply With Quote Quote
Old 18-01-2010   #11
since i've done this, everytime i turn the ignition off, and i turn the ignition back on the CD player resets itself and i lose my preset stations and settings. how can i resolve this
jonyid is offline Reply With Quote Quote
Old 19-01-2010   #12
would i be right in thinking i have to move the yellow wire in the radio (permanent power) to pin 4 to link up with the red/white wire in the car which is from the battery? i think this will solve the problem but not100%
Old 21-02-2010   #13
thxs 4 the guide dude, hopefully this will sort my battery flattening problems
L2wis is offline Reply With Quote Quote
Old 26-02-2010   #14
Excellent guide, took me two minutes.
Thanks!!
Dazz69 is offline Reply With Quote Quote
Comment
Guide Tools
Re: "Wiring A Punto Stereo To Ignition Using ISO" (yellow red wires) ingstyke I.C.E 12 10-08-2012 11:46
(T) Help needed wiring Hawk alarm to the ignition wires. spoonhead Punto (Mk2/2b) 5 28-12-2011 15:57
(T) 06 Mk2B Punto - Stereo turns off when you turn ignition on Finchey101 Punto (Mk2/2b) 5 06-04-2011 13:15
(G) Wiring A Punto Stereo To Ignition Using ISO/fuel gauge issue d siddall Punto (Mk2/2b) 1 09-05-2010 23:24
Yellow Or Red Brake Calipers On Yellow Mk2 Punto fitnessfreak Polling Station 10 08-08-2007 09:53
