PandaPrince
- Dec 29, 2018
- 1
- 1
Hi All,
So. The bulb of my gear stick in my 09 Fiat Panda Eco Dynamic kept coming off when I was driving, so as a solution I super glued it back on.
HOWEVER, now, when I go to put it in reverse the skirt doesn't pull up as high as it used to, so it can be a little tricky to get it into reverse. It doesn't make a loud noise or anything, but I have to feel it into reverse a lot more than I did, rather than just not thinking about it.
I tried to get a knife under the bulb to ping it off so I could re do it but it is well and truly stuck on. So two questions, how much is my mistake going to damage my gear box from now on? And, any ideas how to get the bulb off so I can re do my work?!
Thank you
Thank you
