Hi.
I've had my panda mj for nearly 11 years, and I don't like spending money on it--- and seldom do.
About 3 or 4 years ago, the boot lock started playing up, I think because the mechanism wouldn't activate the microswitch. So since then, I've had the switch hanging just outside, and its very easy to operate, once you are used to it. Its been no problem until today, when for some reason, it won't stay locked. At first I thought that it was a fault with the fob, but when I use the plain key, to turn on the ignition, you hear the solenoid unlock the boot, then, 1 second later, it makes a sort of whooshing sound.
Having searched the forum, everybody seems to think that any problem with the boot is due to a faulty microswitch, but I don't think that this is the case here, because, if you press the microswitch, it does exactly the same thing.
If you switch the ignition on and off a number of times, eventually, it fails to operate the relay, and then, even if you switch the ignition on and off again, the relay doesn't operate. Until you get out, and close the boot.... Then it unlocks again, as soon as you turn the ignition key.
I've checked for engine codes, nothing relevant.
I'm foxed, can anybody help? I'm loathe to take it to a dealer. I've not seen them since I bought a £2 part 4 years ago!
