billysally208
- Mar 24, 2015
- 12
- 3
Hi everyone - Newbie from Derbyshire - have owned and serviced a 2004 Panda Dynamic for over 12months but never had any problems with it, apart from finding which size/sort of oil filter was needed and replacing the front suspension arms which was straightforward enough.
Apologise for coming on straight away and asking questions - but I got the dreaded phone call from my daughter who uses the car to say that the indicator stalk had come off in her hand and she was stuck at work with no indicators. I intend replacing the stalk assembly myself, but would be grateful for any information on how to do the job. I have done some searching around but cannot see a full description anywhere. I understand that I need to remove the air bag/centre pad assembly from the steering wheel, which entails disconnecting the battery allowing the car to stand for half an hour to fully discharge the airbag, which then is unplugged and lifted out of the way. The steering wheel then has to be removed to allow access to the switch assembly underneath , which can then be changed.
My main questions are -
How is the steering wheel removed - is it a large nut holding it in place and is it easy to realign when replacing.
How is the switch assembly held in place - I'm hoping it will be obvious when I remove the steering wheel.
Looked on Eurocarparts for a relacement and they list two for our car - as far as I can see the difference being that one has a computer button (which I need) and the other doesn't.
Finally can anyone suggest where I can source a new switch assembly other than Eurocarparts where it is out of stock - I need one urgently and am based in the Derby/Nottingham area - would prefer to go the new route as opposed to secondhand.
I do apologise again if I have missed the obvious in my search of this Forum but any help/advice would really be appreciated.
Thank you
Alan
Thank you
Alan
