Honda Owner
Hi all, I'd be grateful of some advice about a problem we're having with my father's 57 plate Panda 1.2 Eleganza, which has a 5-speed daul logic gearbox. It has done less than 19k miles from new and recently passed an MOT with no advisories. He has owned it for around 3 years and has had it serviced by his local Fiat dealer, but only a 'short service' (which, I think, means just an oil and filter change?).
For a few months, he has been complaining of severe jerkiness when first driving off in the morning with a cold engine, in fact so severe that a loud banging noise can often be heard both inside and outside the vehicle... unfortunately I live some way from him so have never witnessed this banging in person. However, I managed to visit him yesterday so he was able to demonstrate the problem to me, at least to some degree (the problem was not severe enough to cause the banging noise). Actually, I would describe the problem to be the engine dying under the load of moving off, then rapidly recovering with a thud, then repeating this about 3 times in very quick succession before becoming smooth... this happens whether going forwards or backwards and was still just as noticeable when the engine was fully hot. When hot, the idle is a little rough, with the odd 'pop' from the exhaust suggesting a slight misfire (not sure about when cold). The engine revs fine when in neutral and the car seems to accelerate smoothly under full throttle up to around 5700 RPM, before upshifting, but at slow/cruising speeds some roughness/jerkiness is noticeable. As he gently moves from a standstill, the engine and transaxle can both be seen to 'twitch' quite noticeably.
My father does not cover many miles in the car, in fact a tank of fuel tends to last him a few months. Just in case these problems were related to dodgy fuel, we filled up the (almost empty) tank yesterday and drove it around for a while to see if there was any improvement... there wasn't.
I have an OBD2 reader (a D900 model with real-time mode), which we connected up (no Fiat option in the menu, oddly, but setting it to Alfa Romeo allowed it to communicate OK). No DTCs are active or stored and all sensors are giving variable readings while the engine is gently revved (although I do not know what the ideal readings might be).
I've searched the forum for similar problems with little success, but my apologies if I missed a relevant thread. I can see there's a reported issue with newer models needing a dealer remap to correct a similar problem, but I can't see that being an issue, as the car has been absolutely fine until a few months ago.
I'd obviously be grateful for any advice, as I was reluctant to jump in and start swapping spark plugs or cleaning the MAF (or MAP) sensor (not sure which it has!?) or clean/replace the lambda sensors without really knowing where the problem lays, as my experience tells me that this 'scatter gun' approach is rarely successful and can become costly!
Replies appreciated!
