Hi all,
Some advice please! I have a 2004 1.2 Panda that has a problem when the engine is warm.
First thing in the morning, starts first time and perfectly. When the temp is over the quarter line, starting up without using the throttle is a struggle, constant irregular misfire. On idle when warm, the car pops like crazy. Also under very light throttle, it kangaroos.
I did have error codes saying cylinder 2 & 4 misfire was detected, this always happens at around 2000rpm even with the new coil packs. I had a solid MIL before saying that the car was running rich (sorry I haven't got the exact code, I'll get this another time).
Things I have done so far:
- New timing belt and tensioner (correctly timed!)
- Full service inc New plugs (NGK), coil packs, HT leads
Things I am going to do:
- check resistance of fuel injectors (what are they supposed to be?)
- check for air leaks around the manifold and throttle body
Part of me is thinking that this is an ECU fault & also fuel rail/injector problem.
Any suggestions would be greatly appreciated. I'll let you all know how I get on.
