Old 30-05-2019   #1
Replacing brake fluid- activating the ABS pump
Anyone know if there is a laptop version of the 'dealertool' that Fiat would use to operate the ABS to pump to complete a brake fluid change?
earthman is offline Reply With Quote Quote
Old 30-05-2019   #2
chris3234 has donated!
Re: Replacing brake fluid- activating the ABS pump
Quote Originally Posted by earthman View Post
Multiecuscan should be able to bleed the abs system you'd probably need to software a elm module and a adapter cable to connect to the abs system
You can get them all seperate or buy as a package from gederan
chris3234 is online now Reply With Quote Quote
Old 30-05-2019   #3
Quote Originally Posted by chris3234 View Post
Thanks, I'm only going by what I can see on their website but the screen shot of 'Actuators' doesn't show ABS pump at all so I'm wondering if it can do it??
I were hoping for a system that uses/needs just one cable, the system that I use on my motorcycle does, that can operate the ABS pump via the OBD port only.
Old 30-05-2019   #4
You can download a free version and it will allow you to see everything it can do in simulation mode so you can do a virtual run of all the features
Also mes does have a option to run with one cable called multiplexed version but this is a lot more expensive
Old 30-05-2019   #5
https://www.ultimatecarparts.co.uk/i...yABEgJ0K_D_BwE
Just found this system which does state "ABS Bleeding Function",...no idea if it's any good/better than any other system that's out there.
Old 30-05-2019   #6
KPat has donated!
It's on the "Adjustments" section. Hydraulic unit bleed.
Description:
This procedure will flush the hydraulic lines of the ABS module. Perform the procedure after replacing the ABS unit, or when changing the brake fluid. Keep the brake pedal pressed during the entire procedure. The pedal will first sink to floor and then raise back to top.
Basically the procedure will open all drain valves and fill both accumulators with brake fluid from the master cylinder, then it will use the hydraulic pump to return all fluid back to master cylinder. This way the fluid will be cycled through all internal ABS hydraulic lines.
Before executing this procedure make sure that there is enough brake fluid in the reservoir and also loosen its cap.
KPat is offline Reply With Quote Quote
Old 31-05-2019   #7
Quote Originally Posted by KPat View Post
Description:
Ah, thanks for confirming that this device can indeed do that.
I also have an Isuzu that will need it's brake fluid changed, it would be nice to find a 'universal' scan tool that could do both vehicles.
(T) Grande Punto TJET ABS brake fluid change? everson38 Grande Punto 19 08-09-2017 23:18
(T) Replacing & Bleeding Brake Fluid SB1500 Panda 12 25-04-2016 11:00
(T) Replacing brake/clutch fluid reservoir MikeSalt Punto (Mk2/2b) 1 02-06-2009 15:50
(T) ABS activating under light brakeing john55 Stilo 14 24-04-2009 13:02
(T) Replacing Brake Fluid doctorchris Panda 2 31-03-2009 19:25
