Hi
Wonder if any one has had this fault on there 1.2 panda before.
I have a 14 plate panda lounge which has started to bring on the eml light while standing at traffic lights for longer than 1 min with h/brake on and in neutral, no warning signs or hesitation but when fault appears the engine speed goes up to 1500 rpm until I turn the car on and off again. Had the code read comes up as P0101 mass air flow or volume air flow sensor circuit range performance problem. Have already changed map sensor and cleaned throttle body still no difference. Any advice will be very helpful.
