Two posts on this thread confuse me no end.
The copper grease reply makes little sense, yes some copper grease contains a very small amount of lead, it is meant to be put on the threads very sparingly and it is such a small amount of lead it will not damage your cat or lambda sensor. Although unleaded petrol has no added lead, there is traces of lead in the fuel by nature.
The other post that I feel is wrong is the remark that a plug that has not had the sealing washer properly crushed can cause a piston to be holed due to this, I'd like to read any evidence to prove this as I personally believe it is wrong. The tip of the plug it in the combustion space and the plug body cooled via the thread that is screwed into the head, the number of turns a plug needs till there is contact to the sealing washer means that there will be minimal leakage of combustion gasses through the thread, copper grease on them will reduce this even more, in all my years I have yet to hear of this phenomenon.
