FIAT Auto Specialist Team
Old 14-12-2006   #1
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Green
..... And this is Green!:
More Rock!
Less Roll!
Sprox is offline Reply With Quote Quote
Old 14-12-2006   #2
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Green
Green's problems;
Pale blue smoke from exhaust -
I think head gasket is going . . . . .
Rad water rusty brown in colour...
But that's all really!
More Rock!
Less Roll!
Old 14-12-2006   #3
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: Green
Ooh, I like that. I love the colour. Sexy Panda.
2015 Fiat Panda Pop
Steven is offline Reply With Quote Quote
Old 14-12-2006   #4
Trader Rating: 1
Smile Re: Green
Yes indeed. What a cutie.
* * * PANDA 'R' US * * * (aka MARTIN)
2012 FIAT 500 POP
(Previously owned: '00 Sei Sporting, '84 Panda 45, '94 Panda CLX, '96 Cinq SX,'92 Panda MANIA, '86 Uno 45)
Pandarus is offline Reply With Quote Quote
Old 14-12-2006   #5
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Re: Green
The parking area is starting to look like a piazza Nice gaggle of panda's you 2
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is offline Reply With Quote Quote
Old 14-12-2006   #6
It's a bit noisy
FuzzyPanda's Avatar
Trader Rating: 1
FuzzyPanda has donated!
Re: Green
You need to get 'em all together for a photo shoot! But there's only two of you... So it might take a while.
FuzzyPanda is offline Reply With Quote Quote
Old 14-12-2006   #7
Re: Green
note floyd's under wraps !
just a damn shame you can only drive them one at a time
posh pandas is offline Reply With Quote Quote
Old 16-12-2006   #8
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Green
Ok!
Took Green for a run this morning to re-check head gasket status.
Found an interesting problem on return from 7 mile run . . . .
A tick tick tick sound came intermittently from the engine - I tracked it down to Number 2 (from cambelt) sparkplug/ht lead - it was Arcing across to the cylinder head.
Would this cause similar symptons to a head gasket failure?
i.e. misfire, overheating.
I also found more mud under the car
Also, what is the small bottle and hose behind the front bumper on the passenger side (you have to look underneath.) ?
More Rock!
Less Roll!
Old 16-12-2006   #9
Re: Green
Spark jumping from lead to cylinder head will have nothing to do with the head gasket, just faulty lead. I would be inclined to replace all of the leads as a set. Black plastic bottle fwd of L/H/F wheel is charcol canister, part of anti polution system, would not normally need to be disturbed in any way.
Looks a real tidy example, look after it.
Rgds.
petel is offline Reply With Quote Quote
Old 16-12-2006   #10
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Green
THANKS PETE!
I've got a spare set of HT leads in the garage!!!!!
I'll let you know if it works Ginas 126 has a charcoal filter too!
More Rock!
Less Roll!
Old 16-12-2006   #11
eh?
Trader Rating: 1
Tony M has donated!
Re: Green
Quote Originally Posted by Sprox
it causes the engine to run irregularly... and that's about it. it'll ceertainly impact on the tickover.
Tony M is offline Reply With Quote Quote
Old 16-12-2006   #12
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Green
Right! Have replaced the HT leads - we are back up to Panda power levels now!
The dizzy cap and rotor arm is a mess. Will get new ones!
They're the same as on Flash - I've got a spare brand new Coil - not sure if that will make difference?
WIll also change the spark plugs tomorrow - pain to get to with the Injection Carb electronics in the way - i think I'll have to take off the carb! Prefer a 1000s over this!
Engine temp was down to slightlyabove normal levels but 80 was squueeeezed out over the flat (disused Runway) instead of a previous 58.
just a good service needed now including changing the coolant - hopefully the blue smoke was unburnt fuel blasting throught the CAT type thingy if that's what it is!!!!! WIERD.
More Rock!
Less Roll!
Old 16-12-2006   #13
eh?
Trader Rating: 1
Tony M has donated!
Re: Green
I think that whispy smoke stuff is a sign of being unused for some time... or being used for short runs only i think... also the panda's aren't exactly high precision engines and so balancing the fuel air mix is a little random sometimes.
on the other hand it may be the water in the cooling system being pumped into the cylinder ... it's worth having it checked out for peace of mind.
Old 16-12-2006   #14
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Green
The coolant level hasn't dropped at all - will flush it though.
This panda is on 100,800 miles - it did 3000 last year and 8000 the year before that but it's obviously been recently neglected. The oil doesn't look too bad
The burning smell from engine was probably ht lead and oil, grease, dirt and mud off the arcing
The carb needs a gooooooood clean and I put a new air filter on.
The only receipts with the car are for new wiper blades and tyres plus a new rad cap in 2002!
A new clutch at 57k
Here's a pic of the unusual sump guard:
More Rock!
Less Roll!
Old 16-12-2006   #15
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Re: Green
Quote Originally Posted by Steve
The colour is
Malta Green Metallic! is that the same as the Sisleys?
More Rock!
Less Roll!
(G) Panda Colour Code Steven Panda (Classic) 17 23-10-2012 00:28
Taiwan breeds transgenic, fluorescent, green pig Steven Leisure Lounge 4 12-01-2006 21:00
whats the green bar below join date/ wer we live etc. beau Leisure Lounge 7 28-01-2005 20:21
(G) British Racing Green jasper Punto (Mk2/2b) 9 20-08-2004 23:19
