Both the Sisley's I've had were fitted with the sump guard bar. My 93 CLX which had a cat didn't have one fitted. Strange. Maybe another case of the mix and match style of the Fiat parts department?
seems a little overkill having both... the 4x4 sump guard is surely more than an match for any flexing in the front of the car.Steve said:Sisley's have a large guard that protects the sump and underside of the engine, but the two I've had both has a bar like this as well.
I shouldn't think drilling a hole for a choke mechanism on the plastic facia would require a degree in rocket propulsion...Sprox said:Thinks I can take off the injector carb and put on a good old 1000s carb..... get rid of those nasty electrickery things lke lambda sensors
oh ****! no Choke lever..... oh well maybe I can fit one
Sprox said:The colour is
Malta Green Metallic! is that the same as the Sisleys?
Sprox said:Right!
First time working on a CAT car.
All the old spark plugs looked fine and normal - even No. 2 which wasn't burning the fuel and had the arcing lead.
Had to remove and put to one side the injector carb (seems a waste of time having one over a normal carb to me!) so I could actually get no.2 spark plug out!!!!!!!!!!
No creamy gunk in the radiator so hoping it's not Head gasket now - loing good! but the rad fluid is a very horrible rusty brown colour so just going to flush it now.
The CAT thing (if you can call it that) is after the lambda sensor - which is on the downpipe leaving the manifold. Are yousure I can discard the CAT?
or is that a Norhtern Ireland thing?
I don't think it's been a long term problem with the arcing ........
