Old 07-10-2007   #1
Prop shaft dropped
Done a bit of hardcore off roading earlier and the propshaft has dropped, causing it to knock against the guard constantly.
Is there a coupling I can change in the joint? and if so where can I get one from?, or do I need to get new props?
TIA
Ju
Ju. is offline Reply With Quote Quote
Old 07-10-2007   #2
Trader Rating: 2
allen fletcher has donated!
Re: Prop shaft dropped
Yes the propshaft is carried by two bearings above the cover you are talking about now sit down they cost about 65.00+ vat from Fiat dealer. I think they are still available
allen fletcher is offline Reply With Quote Quote
Old 07-10-2007   #3
Cheers mate. If its bearings then I can get them apart get the numbers and get them from BSL through work saving alot of money. Thats quite a hefty amount really.
Old 07-10-2007   #4
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Have you got a pic, what part has dropped? above the tin plate is two rubber mounts that hold the bearings in place.
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is offline Reply With Quote Quote
Old 08-10-2007   #5
This is the joint just infront of the guard.
Old 08-10-2007   #6
Trader Rating: 2
Hi JU the propshaft that has dropped is it above the metal guard? if ti is two bearings are mounted in rubber that inturn bolt through this plate. When these rubbers get old they crack and the rubber bonding comes off the foot holding the captive bolt that passes through the tin guard. If you can move the prop side to side up and down in the area of the guard then that is what has failed I'v had it happen to me
Old 08-10-2007   #7
Cheers mate. When I get the car back to my workshop I will get it apart and have a look.
Old 08-10-2007   #8
Trader Rating: 2
No probs if you can get the car up in the air it will be easy to spot be careful if you have to remove the bearings and rubber mounts the bolts that go through the metal plate will rip out of the rubber for fun. Heat will knacker the rubber up WD and a lot of luck is what you need, you will need to split the prop to change the bearing don't forget to mark the prop so it goes back as you have taken it apart.
(T) vibrating knocking noise from front drive shaft Marstonmulti Multipla 0 04-09-2007 22:19
(T) Rear wiper motor - how to remove shaft ? tintin Marea 6 02-07-2007 21:05
(G) 4x4 drive shaft making damn noise Jaff_Fox Panda (Classic) 16 26-05-2006 13:15
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
(T) Cinq CV Boot/Drive Shaft rick_p Cinquecento / Seicento 3 05-08-2005 10:39
