Old 16-12-2014   #706
centoproject has donated!
Re: my green cinq project.
on pull it reads in-between 11-12 which is ideal just for that split second it reads 16 just as the boost begins so I'm thinking air pressure reference is not quick enough for puel pressure regulator to up the pressure so I'm going to go out in a min and run no boost and se if its related to boost or not.
and the set up it van anken esentualy k03 turbo on a bone stock 1.1 engine with vananken mf2 fueling rs2000 fuel injector and pump
centoproject is offline Reply With Quote Quote
Old 16-12-2014   #707
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
mmmm, random one that is... I would guess a bit more fuel pressure to the 2nd injector would help? if its a spi sei i would check the pressure across the primary injector as i have found the pressure to vary quite a bit from factory, some are as low as 0.8bar and i have found they need to be 1.0-1.2bar to not lean out as boost comes in and the 2nd injector takes over.. The mpi setup works a bit different being non-return rail - not really messed with a non-return system before myself.
Could also just need to tweak up the fuelling up on the lower part(s) of the mf2
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 17-12-2014   #708
figured it out i thing although its a very strange issue since it ran fine before the head gasket failure hence i trusted it to get me to london instead of going in the up! i think its the boost reference for the fuel pressure regulator i think i will attempt to modify a injector section to bypass the biult in regulator and just run the 2 injectors of the boost referencing fpr. only a temp fix however going to go canems engine management.
also think i may have damaged the turbo with the oil+water flowing through it pity dam head gasket went that very day i had sorted the exhaust leak.
started work on the 1.2 purpose built engine 8v same turbo set up maybe compound with a bigger turbo (dependent how enthusiastic tommy gets turbo guru) or just use a ko4.
will try to upload pictures agin had no luck on phone think the file is to big.
Old 18-12-2014   #709
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
tbh i wouldn't trust a cheap HG on a turbo FIRE engine, i would stick to genuine fiat at least or a payan or spesso one. I would bet this is gonna pop another HG in the not too distant future. Is probably why it went in the first place if it had a cheapy one then.
Look forward to seeing some pics though
Likes Honeymonster liked this post
Old 21-12-2014   #710
Update time its back ! what i thought to be fueling issues and the wideband going all over the place was a simple misfire due to the oil i had spilt down no1 spark plug hole . and the rich showing on the sideband was a slight leak from the turbo flange.
i just love the look on peoples faces when a crappy looking cinquecento flies past 2015 its going to be painted and refinish the abarth parts got to be the worst fitted spoiler ever silicone everywhere .
also had it tracked other day so it now drives nice, going to get a move on with restoring my pentas i had managed to find 4x100 scoured the internet have yet to find the same looking set again in appalling condition but restored the lip with a hand file
Likes ktRinity, hf turbo liked this post
Old 26-01-2015   #711
so yeh 1.2 high boost is in and running brand new everything .
Likes Lecook liked this post
Old 26-01-2015   #712
Lecook has donated!
Quote Originally Posted by centoproject View Post
https://www.youtube.com/watch?v=nf_7M6XgBrc
<3 <3 <3 that noise.... i need to get my turbo engine built
Lecook is offline Reply With Quote Quote
Old 26-01-2015   #713
Yep that sound should be at Stanford hall/brooklands and yes get it done
Old 04-03-2015   #714
right updates pictures to follow... cinq is boosting very well peeks at 25 psi at moment but not that that translates into forward motion :P loads of clutch slip from 3k plus fpr cant keep up it would seam leans out quickly. got the upgrade clutch cars in the garage pulling engine out tomorrow converted to r5 turbo carb now and panda distributor. hopefully that can keep up with the rapid boosting already upgraded the brakes front and back gt3s on the front and uno turbo on the back managed to blow the first turbo (think it was on its way out when i got it) now have an issue with low oil pressure at idle but ordered oil pressure gauge to keep an eye on the stats.
5th gear 70 mph hits boost clutch slips like crazy think this is going to be one fast cinquecento
Old 20-04-2015   #715
updates cinq has 190mm flywheel back on injection and running fine apart from lowish oil pressure think the block was a duff maybe although i have a new project non fiat but cool non the less Stagea RS4 import manual conversion at the moment so cinq is the work horse at the moment and of course loving it as always . plus i have a nice big workshop for all 3 of the toys will upload pictures later...
not been all go though turbo went bang month ago maybe due to low oil pressure or just a dud but as per with the cinq replacing the turbo matter of 20 mins. also while the flywheel was out new seal for the crank (may have contributed to clutch slip). fixed the fuel problem with 2 fuel pressure regs. tb at 1.5 bar and injector at 3 bar both completely separate.
Likes hf turbo liked this post
Cinquecento tesco's wellingborough green cinq Fiatseicento2002 Spotted / Was It You? 0 19-12-2011 23:45
(G) Green Goblin Cinq Garf Cinquecento / Seicento 7 18-06-2008 00:16
Yellow Cinq Wood Green R12MUS Spotted / Was It You? 2 02-04-2008 09:01
Green Cinq outside Kwik-Fit Moose_UK Spotted / Was It You? 1 22-08-2007 19:15
Green Cinq with Extreme Roof Spolier lanciaevo1 Spotted / Was It You? 3 30-05-2005 16:36
