Ok,
I just got a new set of BKracing alloys for my tipo. they are the multifit type so have holes for 100 and 108 PCD. plan was to use the set of wobblies I currently have, problem is, they physically dont fit the holes on the wheels.
the type of bolts the wheels did come with dont actually have a hex bolt on the end for unscrewing like a normal bolt, they have a torx style hole (large alan key hole) for unscrewing and so the bolts arent as wide as normal ones.
problem is now that the wheels dont actually fit as they arent "wobbly" bolts.
so does anyone know where i can get a set of thinner torx style wobbly bolts OR does anyone know where I can get a set of thinner torx style wobbly nuts to use with studs?
the bolts/studs cant be wider than 20mm otherwise they physicaly wont fit the wheels
help!
help!
