The other side
1. pull out battery:
10mm socket to disconnect negative and positive battery connectors
13mm socket with extension to undo bolt holding the battery strap
2. disconnect 2 clips for positive cable
3. disconnect 2 clips for washer bottle (flat screwdriver: marked B) and cable marked C (squeeze with needle nose pliers and push in)
4. pull out plastic tray (don't tear off hose where hole is) and undo three 13mm bolts; pull out the metal tray
5. undo bolt holding bracket
6. support gear box with trolley jack and timber (as or engine mount)
7. undo outer five 13mm bolts; I needed 600mm breaker bar (leave the ones connected to gear box itself)
and install new gear box mount
