![]() | #1 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Exhaust Manifold Studs and Nuts Afternoon all, Firstly, will introduce myself. I'm new to Fiat and have recently Acquired a Fiat Grande Punto, 2007, 1.2 as a fixer upper as it has a fair few issues and it's MOT was due in a few weeks. I have browsed the forum for some useful info but thought I would join and hopefully contribute back where possible and I have one last job to complete and am looking for recommednations or advice. The exhaust system had 2 blows, 1 at the join for manifold to centre pipe and also the manifold gasket. Sorted the the join and moved on to the manifold gasket. After removing the heat shield, O2 sensor etc, noticed that 1 nut and stud was missing and 2 had been replaced with bolts that required an E10 to undo. I installed a stud into these 3 holes just to make sure there were no issues, all holes recieved studs appropriately. Most of the nuts had to be removed with an extractor socket and all the studs came with them. I thought as I am doing the gasket I will replace all the studs and nuts so the future owner shouldn't have to worry about any issues with these should the manifold need removed for whatever reason. So, I want to get the job done as quickly as possible and in for MOT so I phone the local Fiat dealer as I though these little items would be carried in stock. Anyway, nope, they have to order them in. OK, whats the price? I almost fell off my chair when the young chap came back with "for 8 studs and nuts, that will be £58,95 including the VAT". So, my question is, has anyone used the cheaper studs off of Ebay? The studs I have measured out and they are M8, 40mm long. I have measured the ones from the car and they come in at 13mm for the first threaded part that screws in to the head, 14mm for the unthreaded part and 13mm for the last threaded part for the nut to sit. I haven't seen anything on Ebay that match these specs and wondered if anyone had any links to ones they have used in the past successfully. The nuts aren't a problem and can be sourced easily. Anyway, thanks for reading the long winded post and hopefully someone can help out. Cheers, Jamie.
![]() | #2 | ||
Posts: 382 Thanks: 23 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts I bought studs in one small local store focused on Fiat parts. Old guy is working there and has almost everything, used or new. I think those studs can be found on many e-shops or physical stores...just to ask them. I had the same leaks as you...I posted some pictures in some thread...but i dont remember its name...
![]() | #3 | ||
Posts: 3,293 Thanks: 174 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts £60 for 8 studs and 8 nuts isn't really expensive especially for OEM parts it's less then £4 each
![]() | #4 | ||
Posts: 27,820 Thanks: 1087 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts Hi Jamie Try Shop4parts and use the forum discount code Let us know what you find Charlie
![]() | #5 | ||
Posts: 270 Thanks: 14 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts Plenty of m8 x40 stainless with flange nuts on eBay for less than 10 per set, that’s my go to for motorcycle studs, they also have an Allen key slot in for stud removal if required, appreciate all the introducing metal type stuff but I’ve always used stainless and god forbid copper slip and never had issues.
![]() | #6 | ||
Posts: 106 Thanks: 9 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts Fiat part number is 55192175 for the nuts and 13588521 for the studs which are both compatible with Linea and Grande Punto. I ordered the ones from Autodoc which where manufactured by FA1. FA1 part number is 985-823.10 for the studs and 988-0804.10 for the nuts. They were very cheap like 40 cents each and came in packets of 10 pcs. Autodoc isn't very fast to ship the items anymore, so it'll take like two the three weeks. Those OEM parts really must be very expensive pieces of soft metal. ![]()
![]() | #7 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts
![]() | #8 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts You may not find £60 excessive but respectfully, for what they are, I do. If Shop4parts are retailing the same OE (they state the studs and bolts are genuine FCA) items at £28 after discount, taking in to account their margins, the Fiat dealership must be making at least 200% mark up. But then again, if you need them quick and are in a bind, you have no option but to pay the piper so to speak.
![]() | #9 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts Plenty of m8 x40 stainless with flange nuts on eBay for less than 10 per set, that’s my go to for motorcycle studs, they also have an Allen key slot in for stud removal if required, appreciate all the introducing metal type stuff but I’ve always used stainless and god forbid copper slip and never had issues.Attachment 211261
![]() | #10 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Exhaust Manifold Studs and Nuts Fiat part number is 55192175 for the nuts and 13588521 for the studs which are both compatible with Linea and Grande Punto. I ordered the ones from Autodoc which where manufactured by FA1. FA1 part number is 985-823.10 for the studs and 988-0804.10 for the nuts. They were very cheap like 40 cents each and came in packets of 10 pcs. Autodoc isn't very fast to ship the items anymore, so it'll take like two the three weeks. Those OEM parts really must be very expensive pieces of soft metal. ![]() I don't really want to be waiting 2-3 weeks in total for the parts to turn up so have gone an alternative route, thenk you for the suggestion.
![]() | Adaman28 | Grande Punto | 9 | 23-11-2018 21:15 |
![]() | alan01256 | Punto (Mk2/2b) | 5 | 15-04-2017 20:26 |
![]() | rc822 | Punto (Mk2/2b) | 2 | 07-10-2013 13:50 |
![]() | atom0007 | Punto (Mk2/2b) | 13 | 01-04-2013 21:58 |
