Evening/ morning folks.
I have recently purchased a very neglected 56 plate 5d Grande Punto 1.2 dynamic/ AC model with 72000 on the clock.
The car had been sitting for a couple of months before i came and rescued it.
I was told that the car had a few issues and I am making my way through them one by one. The last fault is the PAS warning message. To give a bit of background I'll list whats been done up until now.
Fun so far:
Flat battery (Bosch S4 002 470A 52Ah)
Charged via Optimate 5. Tested after 5 days and found it at 12.87v
Starter motor stuffed.
Replaced and tested (after next fix) now working great.
Grounds checked
Cleaned all grounds. Replaced complete ground wire as the 'T' to the body ground was broken after removal.
Fully serviced + HT leads.
Few other bits and bobs sorted.
The car now runs lovely and quiet apart from the loud BEEP on start up followed by 'power steering fault check handbook' message.
Battery voltage is around 14.4 with the car running. All fuses seem fine.
Plug in diag is not giving up any codes.
Took the instrument covers off to expose the PAS motor and found it has already been replaced with a Fiat 51892279 part around 2011 according to the DOM on it. I checked the connections on it with the battery disconnected and found nothing untoward going on.
Voltage at the PAS motor end is around 14.4 and drops to about 14.2 when i turn the steering wheel slowly. Steering does not feel overly heavy although I've not managed to get out on a proper road test due to insurance and tax.
City mode doesn't seem to make any difference to steering feel and similar slight voltage drops occur at the motor.
Just wondering if there is anything else I can try before forking out £240 on a recon PAS motor? Toying with slinging on a new battery for the sake of it but is there anything else that could be causing this issue?
Apologies for a long winded first thread but any help would be massively appreciated!
All the best
Lewis
Fun so far:
Grounds checked
All the best
Lewis
