Just a quick update, I thought I would have ago at adjusting the left to right cable today on the gearbox, it’s definitely adjusted from we’re it was previously and gear changes seem slightly better, but I haven’t told the Mrs I’ve adjusted it so I’ll see what she says when she drives it,
What I did also notice as well is when I press the clutch there is a creaking/squeaking noise, It’s 100% coming from the clutch slave cylinder, so I’m guessing it will also need a new one of these,
Am I correct in saying it’s only 2 bolts and remove the fluid hose and it’s off?
