Old 28-08-2019   #91
Belgium
Re: Tell me about Punto 1.3 dizzle
Quote Originally Posted by levemircento View Post
generic code reader not picking anything up
Another reason to buy MES ...
BRs, Bernie
Likes Pugglt Auld Jock liked this post
Old 28-08-2019   #92
Pugglt Auld Jock has donated!
Quote Originally Posted by Bernievarian View Post
BRs, Bernie
Bernie's advice is good. We've had Panda's in the family for years as learner cars for children and town runaround. I havered for quite some time (not unusual for me) before deciding on MES and was finally tipped over the edge when my oldest boy bought a '12 plate Punto and we finally parted with our old Panda Parade replacing it with a '10 plate Panda Dynamic Eco. These newer cars need software simply to reset the service reminder! Of course there is a whole raft of other, quite simple, and extraordinarily useful, "stuff" you can do and a load more advanced stuff you can safely learn about as your knowledge progresses - MES is very good at giving you instructions and prompts when you are using it. I would strongly advise you to download the free software and run it in "simulate" mode where you can select individual vehicles and observe what is possible to do. The other thing I think is good to do is to buy from an approved supplier. I would have no hesitation in recommending Gendan - where I bought mine - You can ask them lots of questions before you buy and you will get interconnects which work out of the box (a certain amount of configuration to your laptop and vehicle is required and I would advise you to follow the enclosed instructions closely as getting just one thing wrong stops the process (I know, been there!) but a quick phone call to Gendan and I was up and running. Several Forum members made useful contributions too.
I use mine to do a whole vehicle scan before starting work - You know then whether you've caused an additional problem when trying to "sort" whatever you are working on. Getting fault codes displayed that you know you can rely on (generic code readers sometimes lead you down the "garden path" with their results) is a major benefit. I also find being able to graph sensor outputs etc very helpful when fault finding. A couple of years ago graphing and understanding what something was trying to tell me would have been like "black magic" but you find the more you use it and experiment the more useful it becomes. When I bought mine I hoped it was going to be useful, even if only for resetting the service, but now, some two years later, it's become an atomatic "go to" whenever I'm working on anything not strictly mechanical.
So, doing your own services and repairs? Buy your own licenced copy, You'll find it indispensable. - and there's a wealth of resource in the knowledge base of all our friends here on the forum if you need help.
Likes Bernievarian liked this post
Pugglt Auld Jock is offline Reply With Quote Quote
Old 28-08-2019   #93
Belgium
If you're still hesitating after that one ...
Cheers, Bernie
Old 31-08-2019   #94
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
hiya, I have ordered the adapter and am waiting for it to be delivered
in the meantime, my friend plugged his laptop in that has something similar called multidiag, he used this system when working for a recovery company/breakdown service
anyway it showed up a fault as being the pressure converter, which is the small valve just below the slam panel which controls the vac to the actuator, this was a couple of days ago and I jumped on the 'net and bought a brand new one, its coming from Germany.
This afternoon I have had the original valve out, rigorously used my vac pump on it, the valve itself makes a few wheezing noises, not entirely healthy, I tapped it, sweared at it, and refitted it, upon driving I can only describe the car as being normal! and OK! - power in a useable place in first gear! I was initially just going to drive it from my back yard round to the front of the house, but instead as the car was driving that good I just done a 40 mile trip halfway up the M56 and back!
however after restarting after a visit to the shop, it was back to being poor.
But I know what the fault is, and the part is on its way.
And so is an adapter, so I can use MES, in the future.
must be time for a brew
levemircento is offline Reply With Quote Quote
Old 01-09-2019   #95
Belgium
Good decision !
first thing you'd do with MES is to plot the Actual Boost Pressure vs the Expected Boost Pressure and see the discrepancy with a deffective vacuum system... You'll be also able to see any improvement when adjusting (slowly!!) the linking rod length, and discover A LOT of very interesting stuff with that little gemm...
Cheers, Bernie
Old 15-09-2019   #96
Get a wriggle on!
so in the last couple of weeks car has been in daily use and all has mostly been good
I had the EML come on during a trip home one night, and it went into limp mode, but then the next day it was fine! this was before my MES adapter turned up.
I now have MES, is there a way to find previously stored codes?
One thing I have noticed, that crawling in traffic and at standstill/idling, there is a diesel fume smell in the cabin, theres no loss of diesel anywhere in the engine bay, the exhaust seems ok throughout its length, bulkhead has no holes or gaps in it.
Old 15-09-2019   #97
Belgium
That diesel fume odor usually comes from the EGR flange that doesn't seat well (if it has been removed for cleaning) or from the flex at the exhaust piping...
BRs, Bernie
Old 16-09-2019   #98
Get a wriggle on!
I have had a look at near where the EGR is, its too busy round the back of there to look or even feel for the bolts that might fix it on / together, it might be easier to see from underneath.
I think flexy is ok, later this week I will get the front up on ramps and have a look at this and the other.
Old 17-09-2019   #99
Belgium
It's crowded there indeed, the flange I'm refering to is the conical one at the end of the corrugated "flex" inox pipe that comes from the EGR itself to the cooler. It has a sort of clip AND A WASHER SEAL that if not well fitted/tigth would generate that stincky odour... It can be "accessed" from the top with the air box removed.
BRs, Bernie
Old 17-09-2019   #100
Get a wriggle on!
BRs, Bernie
I will have a look, are there any diagrams of it around?
Old 08-10-2019   #101
Get a wriggle on!
so although my GP's MOT doesnt run out until mid November of this year, I took it today.
Reason being is that 1. if there was anything wrong I could see to it now while we still have half decent weather, and 2. I dont really want to be fixing cars in november, I work on them outside in the yard at the back of my house.
anyway, IT PASSED
So I am happy with that, there was a couple of minor advisories that will be sorted in due course
Old 16-10-2019   #102
Get a wriggle on!
I am not far off 3 months of ownership now and although there have been problems, all is well and calm and the car is just being driven
I am happy with how it drives, coming from an MG ZR I would say that the suspension in this Punto is just as firm - firmer than i thought it would be, and it handles just as well, I think the steering is excellent as are the brakes, if there was one thing I could fault is that it is still laggy in first gear pulling away, and it can catch you out sometimes.
I am annoyed that the AC didnt allow regassing, but hey ho, my last car didnt have it, I reckon its probably the condensor [AC radiator] that is rotten, but I dont really fancy removing the front bumper etc to check.
the car is comfortable, quiet, and [when used] the factory stereo is quite good, I have had to replace one door speaker already cos when I had the problem with the lock I saw that the speaker cone was rotted away, so I just got a used but good one, I am wondering whether to replace both with new aftermarket - any direct fit suggestions?
I have learned a lot about the car and mainly its engine in a short time, which was one of my aims, at the moment its just day to day running and all is well.
Thanks Bernievarian thanked for this post
Old 17-10-2019   #103
Belgium
Thanks for that update !
And happy to hear that you appreciate the Grande; probably one of (if not) the best in its category...
BRs, Bernie
Old 29-12-2019   #104
Get a wriggle on!
another update!
all is going well in general with the GP, I had an issue with the starter not engaging now and then, but that seems to have sorted itself out, I did check for loose connections etc
sometimes when cold it was a bit sluggish at starting, so I bought some new glow plugs, I noticed that pressing in the clutch when ice-cold starting was an instant fix! so have not needed to fit the glow plugs.
I did replace two more injector seals [also helped the starting], which went well apart from me plugging in the MAF sensor the wrong way, am sure the plug is designed to fit one way, but on mine it fits both ways.
While I was in MES trying to figure out why I had engine light, it fixed itself once I had the plug in the right way, anyway since then I have looked at the "reset self-learnt functions" thing
I did it, and also did the same for the MAF and injector pump, since I did that the car seems a bit perkier, less smoky [could only notice that at night, looking in rear view]
The only thing that is bugging me now, is the boot light doesnt come on when opened, it never has while I have had it, it has a new bulb, I cant find a fuse for it, it might share a fuse with another circuit but everything else works ok.
Old 30-12-2019   #105
varesecrazy has donated!
Depressing clutch when starting means you are cranking less metal ..in cold oil
The HP pump relies on speed to deliver the high rail pressures required for injection.. so the quicker you can spin on the starter.. the better.
Ive recently bought my 3rd gp mj
1st car has done well.. but Ive struggled to sell it with a short MOT.. so will have to get the handbrake adjusted.
I take it yours is Dynamic trim?
Brake pad and disc change - Grande Punto + Punto 2012 + Punto Evo scoop_987 (FS) Brakes 6 15-07-2019 21:52
