Old 08-09-2016   #1
HeaterBlower, out of ideas to fix it.
Hi Everyone
First time posting here, hopefully I've got it right. I have a 2007 Punto Grande Active 1.2. Recently bought. The heater/blower does not switch on.
I have tried the following.
a) Tested the cable that plugs into the blower with a voltmeter, and it showed power when i switched it on/off from the dash.
b) replaced the resistor under the glove box, didn't work.
c) replaced the whole blower unit (new), still doesn't work.
I have not checked any fuses. Nothing i can find online/in manual tells me which fuse box/fuse position the blower unit is connected to. However if there is voltage in the cable, then surely the fuse is not at fault? If anyone knows where and which position its supposed to be that would be great.
I'm out of ideas.. any help would be hugely appreciated.
Damian
Damotron500 is offline Reply With Quote Quote
Old 08-09-2016   #2
Romania
Re: HeaterBlower, out of ideas to fix it.
if you still have the old blower try and find out wich are the wires that make the blower turn.
then put power to your blower and get it working.
Then you know you have a electrical problem.
You need to check power coming to the blower with a load on (something like a 12v light bulb).
You need to check for +12v and for a good ground.
aurick86 is offline Reply With Quote Quote
Old 08-09-2016   #3
Thanks, I'll give that a go. do i need to find a 12v power supply, or can i use the car battery with crocodile clips?
Old 08-09-2016   #4
Romania
the car battery for the tests.
Old 29-09-2016   #5
Have finally gotten round to testing the blower motor. I procured some alligator grips and tested the old, now replaced blower on the car battery.
Damn thing worked. I guess that means I have an electrical problem.
Should I take it to the shop now?
If so.. given that i bought it for 1400, how much is too much before it makes no sense to get repaired? Its a 2007 1.2 model, with 95K on the clock, runs fine.
Old 02-10-2016   #6
Just had the same problem with daughters punto grande, have a very close look at the connection from the wiring loom to the resistor pack, separate the wiring loom from the resistor pack and check the connector pins for arcing and the wiring for signs of overheating, and wiggle it about and it may work, pretty sure that is where you will find the problem.
3rdboxcar is offline Reply With Quote Quote
Old 02-10-2016   #7
varesecrazy has donated!
Quote Originally Posted by 3rdboxcar View Post
hi,
pics here;https://www.fiatforum.com/grande-pun...eater-faq.html
if the loom is past it..,( will pass 12 volts - but not enough current to power a motor)
it's cheaper to get the original Corsa loom for GM , than to get the FIAT badged one..
Charlie
Old 02-10-2016   #8
I have just bought a connector repair kit and new resistor pack from ebay
Old 03-10-2016   #9
Ireland
Easy and cheap repair for the resistor here, don't forget that this usually blows due to strain on the motor, bushings get dry and need cleaning and lubing.
https://www.fiatforum.com/ducato/335...-resistor.html
digger58 is offline Reply With Quote Quote
Old 03-10-2016   #10
Thanks for the replies all.
I have taken it the shop. The mechanic says its a wiring/loom fault. I couldn't see any damage on it personally. TBH, i just wanted it fixed.. 160.. I hope im not being mugged!
Old 03-10-2016   #11
Quote Originally Posted by Damotron500 View Post
you're paying @60 an hour labour , and the 30 for the part
Old 03-10-2016   #12
Up to no good somewhere..
maggers's Avatar
maggers has donated!
The problem, and it affects a lot of cars with Renault Meganes being a repeat offender, is caused by the pins on the connector being too small to take the current so they overheat & melt the plastic. If you look at the replacement connector and new resistor you will see that they now spread the load over 2 pins instead of 1 for the feed & earth.
Likes cmosfxx liked this post
Please note any offence caused is purely intentional
maggers is offline Reply With Quote Quote
Fiat punto grande to fix or not to fix? Antjp Newbie Central 3 04-01-2016 06:50
(G) any ideas on what it'll cost to fix up jetlag Multipla 14 17-03-2014 19:58
(T) Fuel filler cover - any ideas to fix? 850kd Stilo 4 14-03-2009 10:04
(S) opions on my ideas and some inspiration/more ideas please (BORING WTF THREAD ALERT!) Vimto Rolf Grande Punto 96 12-10-2008 12:51
*OT* Fix Or Repair Daily KA, please help me fix it! lol Dan FIAT Boo Archives 20 11-10-2005 12:15
