- Mar 12, 2015
- 239
- 50
I'd be sticking it back in unless you want to spring a leak in your radiator from stones and road debris.
It is not just there to make it look pretty. The radiator is probably showing behind it, the grille helps protect the rad from damaging debris. Swearing a lot and refitting it is better than a new rad, or worse a seized engine when the rad lets go.
Yeeah I know not that dull haha and It's just for the time being until I get some tiger seal to fit it right back on
Meanwhile the flying rocks won't care that you intend to cover it again next week. They'll still come at you. Good luck.
Remove the screws under the bumper. Then you can insert it in easily
btw. no it looks stupid without a huge intercooler there hah
yup then you can stretch it enough to fit the grill
When I bought my grande it was missing this grill and to be honest the holes in it are so big it's not going to stop much, only the bigger rocks and boulders
That said I replaced it and found it is very hard to push back in, I knocked it back on to its clips with a drift and a hammer being careful of the paint
