Specs43
- Joined
- Feb 12, 2020
- Messages
- 54
- Points
- 94
Well lads, having on going issues after a new clutch install done a few months back. Issue one being jerky changes in the lowering gears meaning I have to tip toe of the clutch between shifts in order to get a smooth shift. Feels very similar to when an engine mount is going but the gearbox mount was replaced and the rest are fine. Issue two being a ridiculously high bite point and a lot of free play in the pedal. Have brought the car a Fiat specialist who tried bleeding the clutch and had a general check over to no avail. The only thing I can think of is I sourced a bit of a mix and match with parts for my mechanic, it’s a luk disc and pressure plate and a sachs csc bearing and we didn’t replace the flywheel. Could there be small differences between the the luk and sachs parts causing these issues. Any suggestions would be hugely appreciated as im beginning to hate driving the car and I really don’t won’t to get rid. Thanks Ronan.
