Thread Tools
Old 21-04-2010   #1
Rear brake drum nut
Hello does anyone know the size of socket needed for the nut on the rear brake drums on a 1.4 8v, as my grande failed its 1st mot this afternoon on 4 problems, back brakes/handbrake being one of them, was advised the shoes need replacing, or cable needs tighting up.
Any help will be much appreciated.
My Weather Webpage
2007, 1.4 Grande Punto Active sport, New Orleans Blue, standard rim's, 70% tinted rear window's, Sony Ericsson Bluetooth handsfree.
JonseyMJ07 is offline Reply With Quote Quote
Old 21-04-2010   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Rear brake drum nut
I dont think you need to remove the hub nut
I "think" that you just have to remove the 2x torx bolts then the outer drum slides off over the shoes
no doubt someone will be on soon with the answer
what exactly did it fail on Handbrake efficiency?
Massive gash
Just a little touch up
Old 21-04-2010   #3
Trader Rating: 2
colin79666 has donated!
If there is too much travel on the handbrake lever there is an adjusting nut inside the car. Just take the cover off around the handbrake lever and you should see it.
colin79666 is offline Reply With Quote Quote
Old 21-04-2010   #4
Yeah something about handbrake efficiency, and no reserve.
I did try and take the drums off about 8 weeks ago to find out they squeak when i release the handbrake or brake pedal, but could not get them off.
My Weather Webpage
Old 21-04-2010   #5
Moderator
Andy Monty's Avatar
so it passed on the foot brake test?
if so as above
Massive gash
Old 21-04-2010   #6
Yeah passed on the pedal, just failed on nearside bottom ball joint and split on nearside CV gaitor.
My Weather Webpage
Old 21-04-2010   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
As Andy said remove the 2 torx screws first.
Next buy a hammer and hit the drums near the centre then with 2 levers (or decent strong flat screwdrivers) lever drum off over the shoes.
Old 21-04-2010   #8
Trader Rating: 10
dave has donated!
or use 3 leg puller
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 21-04-2010   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
or if your a real man, headbutt it
Thanks alexh365 thanked for this post
Old 21-04-2010   #10
Moderator
Andy Monty's Avatar
suppose the handbrake cable needs fully slackening as well first........
Massive gash
Old 22-04-2010   #11
MiTo 155
alexh365's Avatar
Trader Rating: 2
alexh365 has donated!
Quote Originally Posted by T14086 View Post
This how you train your apprentices?
alexh365 is offline Reply With Quote Quote
Old 22-04-2010   #12
Moderator
Andy Monty's Avatar
Quote Originally Posted by alexh365 View Post
Think his last apprentice is still at the parts counter whilst they go look for the Long stand he asked for............
Massive gash
Old 22-04-2010   #13
Forum Moderator
T14086's Avatar
T14086 has donated!
Nope....he's getting me 3 foot of fallopian tubes
Old 22-04-2010   #14
And a glass hammer...
D4nny8oy is offline Reply With Quote Quote
Old 22-04-2010   #15
Trader Rating: 10
dave has donated!
Quote Originally Posted by D4nny8oy View Post
Thread Tools
(T) rear brake drum stuck Rotski Panda (Classic) 25 08-03-2010 11:22
(T) Warped rear brake drum? nmrmak Cinquecento / Seicento 19 10-07-2008 02:05
(T) Rear Brake Drum Shoe Springs cinquecat Cinquecento / Seicento 2 29-07-2006 21:53
(T) Rear Brake Drum overhaul SkinzCinqSporting Cinquecento / Seicento 33 01-05-2006 18:45
(T) Rear Brake drum Seizing Matt925 Cinquecento / Seicento 5 13-11-2005 23:41
