Harper said:If things don't work out and the cinq isn't ready in time for Cupar you're welcome to grab a lift with me if required. I'm heading down Sunday morning and will probably be going through Dundee at about 8-ish
Thanks, Though i do think it'll still be ready... it just means i'm going to have less time to make it look nice and test reliability etc, hoping to get a good run at it this week.
Got a few wee things done tonight, Thermostat fitted, throttle body swapped over for a bigger one off of a brava 1.6. The bottom part of the inlet is now on. Stripped down the last yucky bits off the driveshaft cups too.
Stripped down the cinq loom, chopped off the d4 with spare wire, so that's all ready to go together onto the punto loom, just need to prep the wires to connect them up and re-route the ecu plug to the other side of the bay/extend a couple of wires.
Really, with that gasket (which i'm assured will come tomorrow, we'll see), i'm probably one days work away from a test fire up....
famous last words :laugh:
