Hi all, so again, I´m putting together some fast cento.
My previous work:
maybe you remember.
Now the car has got 128bhp
So, since I have nothing to do, I decided to built another cento.
So I bought Yellow one for regular price...
Nothing special, just serial cento. I haven´t yellow one owe yet.
Problem was hot start.. So I found some ancient alarm system and immediatelly kick out..
I had some better brakes from Uno Turbo, ...
And here is the donnor. Punto 75HSX
Some polishing
..and some drag racing
..anyway, it´s current position
..some new cooler
Engine preparation for removing. That´s what I like on Cento. It´s always funny easy and I can pull engine myself.
Oil everywhere
..some weight shedding
MPI intake slightly modified. Brake servo now coming from another place, because old tube is hitting heat shield, so now shouldn´t be prolem.
Some meassurement, some hammering, TB 8V MPI compare with 16V Punto and 16V Bravo...
...and few hours later, here is result. Adapter from Bravo 1,6 16V TB (48mm) to serial intake manifold 8V MPI. Good thing is, it´s also 48mm. So Airflow should be laminar. And one more advantage. You can install any hose from Fiat directly on TB.
180l/h twinspark fuel pump
meanwhile serial engine is out.
..now for the hard part.
I had 6speed gearbox from Stilo without differential (or with, but it was smashed on 1000pieces) So I´d like to put it to Cinque transmission. Horewer Stilo has got removable differential on screws, Cinque (Punto doesn´t have. That´s what I realised moments after I disassemble gearbox
Stilo Differential was 14/57 (4.08) Cinque 15/58 (3,87)
So anyway, I cleaned out and assembly back.
I remove all holders, plates, etc and put into bag
and went for sanding procedure...
..meanwhile I cleaned 75HSX engine
..and some marine color for everything
and some bushing from Poland arrived (same quality like powerflex, but much more cheaper)
and finally I print out (I have 3D printer) prototype for TB spacer
So I´d like today to assembly engine together with gearbox and holders, but I don´k know how in England, but in Czech There should be approx 20-25°C and sunny (or partially cloudy). But it´s raining for 2 weeks now and no stopping. So I have time to insert this thread, because you can only sleep or browse internet. I will continue tomorrow....
My previous work:
maybe you remember.
Some polishing
..some new cooler
Oil everywhere
