MintySport
Established member
righty, i got my new guage and pipe insert from demon tweeks fitted to my sei sporting in the heater matrix pipe which comes off the head (good place?)
and the guage works okish, it reads a normal temp when driving normal of bout 96-99'c!! is this right?
i dunno but my mate says it shud be bout 90'c and the fan kicks in bout 103'c on the sei sportings.
i dunno if i got something wired up wrong or what. the fan kicks in when guage bout 103'c so i think he right but im bit para bout my engine bein at 96-99'c all the time!!
could a bad earth from the sender cause this problem or the internal flow of water cus the sender isnt actually in the flow of water with thee way the insert is designed! or have i just picked a bad place to put it? iu know some people use a resistor in line to correct any temp errors, what value is it?
i half drained system too and put 1l of anti freeze in and topped up with water but im wondering if i put tooooo much antifreeze in!
plssssssssss can someone help, especially silversei cus i know you got one in!!
