- Oct 9, 2006
- 774
- 227
Hi there,
after approx 4k miles after cat replacing, engine light back again, with "2nd o2 sensor fault", so get to garage to reset, and after 50 miles, its back again.. if lambda is definitely faulty, it should be reporting errors right after next start after ecu reset, isnt that?? checked sensor connectors, respray with contox spray, will go to garage later.
if its only one-time error, the engine light will stay, but will it run normal or need to go to reset again?? any way to get rid of "engine" light without connecting to that diagnostic thing?? becuase garage is taking money for that
also have some working spare lambda from old cinq spi, will it work too in MPi????
Thanks guys
Thanks guys
