Hey guys!
I like to remove the vacuum servo/booster and build in this beautiful pedal-box with a bias bar :
I still need to calculate what the actual required pedal force is going to be (cylinder size, pedal length, etc.), to know if it's even realistic. But need to overcome the worst downside first, which is the need for a hydraulic clutch! But here is the situation:
My clutch has recently failed and I like to uprate it into a stronger one, because of the lovely horses from my whooshy turbo! The cable is getting weaker and weaker (known issue) and gearbox is not in it's glory days, so to speak
So, I had a good 3 day search over the forum, and I was wondering if it's possible to fit a stilo 1.4 16V 6sp. gearbox to the standard 1108 SPI (under)block? The reason I came to this solution is the fact that with it's flywheel included it's the clutch upgrade I wanted and it has a hydraulic clutch system on it :worship:
So is this a wonderfull :idea:, or more a :bang: solution?
