Old 06-10-2004   #1
Chris
Trader Rating: 2
Bushboy has donated!
my misfiring problem
i really need help here. the problem still persists and is a mechanical fault and not what i thought it was.
Ive replaced the split vacume hose but the problem is still there. As ive said before, the problem started about 2 weeks ago, then the exhaust broke and the misfiring went away. now ive fixed the exhaust the misfiring has returned.
im really stuck with this and if anyone has any idea of things i could check i would be really grateful!
thanks
Hi!
Bushboy is offline Reply With Quote Quote
Old 07-10-2004   #2
Smile Re: my misfiring problem
my sei sporting was misfiring really badly and i solved it by treating the little darling to some 4 point racing ht leads. Although these cost about 70.00 from Motor World. well worth the money in my opinion. you could also try dropping some spirits straight into the carb...that seems to clean the whole system. worked on mine....
my seicento may be small but you wouldn't want it on your head.
2000 (x) sei sport. racing ignition leads, k&n 57i filter 13" 3 spoke ronals. 12" 700w sub. 300w and 400w amps, 360w 4 way 6x9's, 100w 4" front speakers with tweaters
seisport is offline Reply With Quote Quote
Old 07-10-2004   #3
HP
I was only doing 80...
HP's Avatar
HP has donated!
Get a compression check done, plus when did you last have new plugs and leads?
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 07-10-2004   #4
Chris
Trader Rating: 2
think i changed the plugs when i got the car (cant rermember tho if it was me changing the plugs on the uno prior to sale or if it was changing the plugs on the cinq after buying it... it was all on the same day you see lol
but ive never changed the leads...
Hi!
Old 18-11-2004   #5
joecinq has donated!
Hey bush, did you ever solve this problem?, as i have got it with mine
thanks
Joe
3rd Fiat - luck as good as ever
joecinq is offline Reply With Quote Quote
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto (Mk1) 8 10-09-2010 09:17
(T) Clutch / Gearbox problem with 1999 Punto Gorskar Punto (Mk2/2b) 7 02-10-2004 12:15
(T) Tip timing problem? Akeldama Tipo (Classic) 4 01-08-2004 06:54
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 19:58
Brava lockup problem Kensho Lets Talk FIAT 1 11-11-2003 03:05
