black cinq-
Bleeped the car jumped in , put key in ignition, and nothing, no a single light, as if the battery was disconnected...
Had a look and couldnt see any reason, then from no where it turned back on again. The cd player started having a fit, the amp didnt power up so i switched it all off again. The clock was reset.
Tried again and the car turned on fine and everything worked the way it should.
Got to the car park, took keys outs and it did the same, as if the battery was dissconnected. I waited for a minute or two and it all powered on again. clock was reset again
I checked the earths fuses etc all seems ok. Any ideas? Bad connection at battery??
Help!!
thanks
Help!!
thanks
