Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->1.4 engine into a cinq (useful info and links)<!-- google_ad_section_end -->
Published by Dan
28-08-2010
Difficulty Level: 1
User Rated:Unrated
This guide is for the stilo engine. It will also apply to 1.2 16v engines as well, but if your going to the hassel of a 1.2, why not a 1.4?
I also take no responsibility for anyything whatsoever, the guide is designed to assist your own knowledge
Before we start, make sure you understand the costs involved in this swap, not only for the parts, but the insurance as well. Most companies will not insure this engine swap due to the dramatic increase and the fact that it has not been in the car 1 year +. However Adrian flux are very understanding.
I have no knowledge or info on removing the variator/putting a plate over it, so will not cover this. It is fairly straight forward according to Aaron (J333EVO) and you may find more info in his thread. Other than that the engine from the grande punto is pretty much the same.
Before we start you may wish to look through these threads as they are also great sources:
https://www.fiatforum.com/cinquecent...v-project.html
https://www.fiatforum.com/cinquecent...nt-thread.html
https://www.fiatforum.com/cinquecent...t-1-4-16v.html
https://www.fiatforum.com/cinquecent...-2-begins.html
https://www.fiatforum.com/cinquecent...-turboing.html
Also my own thread which has lots of costs and part numbers that may be of some use:
https://www.fiatforum.com/cinquecent...1368-cinq.html
Before you carry out this engine swap:
Make sure that the suspension has been upgraded and the brakes have also been upgraded or do not continue. For brake upgrades please see this guide:
https://www.fiatforum.com/cinquecent...-upgrades.html
This guide also covers removal of the charcoal cannister system. Although it is not environmentaly friendly it creates a nice bit of space in the engine bay.
Contents
<< <    Next Page: Parts required (Page 1 of 15)    >  >>
Old 15-09-2010   #1
Trader Rating: 3
Dan has donated!
Re: 1.4 engine into a cinq (useful info and links)
Just to add. If using original cinq dials, the rev counter will not work until you connect the blue wire from the punto loom to the back of the rev counter, as shown in the guide on how to fit the 1108 dials into an 899.
1.4 16v cinq complete 'ish'
Dan is offline Reply With Quote Quote
Old 05-04-2011   #2
Quote Originally Posted by D4NS View Post
Hay is there any one out there that can tell me with this engine change the punto 1.2 16v parts i need to buy do they all have to be from the mrk1 or will mrk 2 bits work please some one help me pm me if u have any clue
1972reg is offline Reply With Quote Quote
Old 22-03-2012   #3
Trader Rating: 1
Question Re: 1.4 engine into a cinq (useful info and links)
Any chance of a picture of "Punto Black/red going to white relay box on loom to cinq bullet connector" as isnt this the only wire that isnt part of the 'D' connector?
Many Thanks!
benwyl is offline Reply With Quote Quote
Old 22-03-2012   #4
Trader Rating: 3
Dan has donated!
Unfortunately this was quite some time ago now and i changed to megasquirt not long after. Try asking YcMing for wiring colours as hes got it down to a fine art now and has done this recently.
Old 15-09-2012   #5
hi there,
im doing a 1.1 8v to 1.4 16v stilo engine swap ,, can u tell me what engine loom i need to use ??
can i use the stilo loom or cinq loom ??
or do i need to purchse another loom ??
your help would be much appreciated on this
thanks
ashhurcs01 is offline Reply With Quote Quote
Old 18-09-2012   #6
Trader Rating: 3
Dan has donated!
Page 2 under parts needed = fiat punto 1.2 16v Loom
Old 12-01-2013   #7
Trader Rating: 1
This the same sort of wiring will need be done on 1.2 16v?
spookycinq is offline Reply With Quote Quote
Old 01-05-2014   #8
Portugal
Nice post
I have a small question in page 14 that plug is the plug that conects engine loom to interior loom right ?
cheers
JotaSequeira is offline Reply With Quote Quote
Old 11-04-2021   #9
Italy
hi guys, I know that for many this project has been dealt with several times, but I would need a hand. I would like to understand the connector where I have to redo the connections, so as to communicate the wiring of the 16v point, with the car wiring of my Seicento SPI. Thank you in advance and I apologize for my English, I am Italian and I use the translator.
virgilio87 is offline Reply With Quote Quote
Comment
Search this Guide:
(T) need some info on fitting 1.2 16v engine in cinq kyle20 Cinquecento / Seicento 8 20-03-2010 21:49
(T) DROP LINKS (OR ANTI ROLL BAR LINKS) - If I don't fix now is this a nightmare? PAULH Stilo 21 21-09-2009 12:57
(T) Engine info think i have a different engine than the original? HELP geck0 124 Spider (Classic) 11 29-10-2006 22:07
Engine info. think i have a different engine than the original? HELP Mark_Holland Lets Talk FIAT 28 13-10-2006 16:09
