How do i find a connection to the console in the roof of the bravo, with the interior lights. As i don't think there is any power to this - no lights work and owner said bulb is replaced.
There are two screws to remove then it comes away from the roof so you can get in and have a look. Fuses are at your right knee as you sit in the drivers seat
as the sunroof leak affects every bravo/a its not too hard to imagine a previous owner removing the courtesy light when attempting to solve the leak, and then forgetting to reconnect the wiring multiplug on refitting the light.
the 2 screws holding the light in are hidden behind a couople of semicircle shafed plastic covers, they pull off easily enough.
as long as the alarm hasnt been disabled because it had a fault then you should be fine. its almost always disabled because the remote has stopped working due to flat battery or damaged connection on the button solder.
when i got my bravo one alarm had a flat battery and the other had snapped solder on the button. both work perfectly now
