- Sep 6, 2019
- 25
- 8
Hi all,
I’m going to be fitting a 700cc D’Angelo Motori engine kit to my 500L, and was originally planning to stick with the 500 gearbox (albeit fitting a 5 speed conversion). I have however just secured a NOS 650 ‘box with 500 driveshafts fitted and given the synchro, would prefer to use this box.
So my question is, should I fit the 500 bellhousing to the new 650 ‘box, or try and source an old 650 engine as a base for my rebuild? I thought the latter, as I understand that the 650 crank and block are stronger, but spare engines seem to be a little thin on the ground nowadays.
Your thoughts/advice would be very welcome!
