To clarify- it does not have resistance to the idle or make any noise while the clutch is pressed.
Andrew, Don't run it - it sounds awful !!!! Have you changed the gearbox and internals around ???? If so did you put everything back together as it came apart ??? If not have you set up the Diff backlash and the Driveshaft turning torque ???? Get the box seen to before any lasting damage is done.
Ian.
