Well, one of those days today. Wasted about 4 hours replacing perished rubber gasket on driver’s side window today, and well, it has to be redone.
I used a replacement gasket from the big NL supplier, but as it went in, it clearly was about a finger width too large. So I cut a small piece out of it on the leading edge, thinking I could just butt the ends together. Um, no. It now has a 1mm gap. What was I thinking? The window hinge rivet was easy to drill out, but oddly the hole on part 1 of the hinge is smaller than the hole on part 2 by a hair. This means I’ll have to keep fiddling with the small stainless nut and bolt I fitted to reassemble it, or drill out 1 hole to make them the same. (I’d love to use a replacement rivet, but I don’t have a tool capable of deforming the bottom of it, especially working right against the window.) Lastly, I struggled so much to get the window bottom pivot pin back in, that I badly scratched the aluminum window trim, and now I’ll probably need to upgrade that
I didn’t realize until after an hour of struggling, that on my car, the pivot loosens with the two screws along the door frame top and leading edge (at least that’s what I loosened to get it to finally slide back home). Thanks Haynes manual - not!
To help with round 2, anyone have thoughts on:
- sourcing a high quality rubber replacement quarter light gasket that fits? I have a 1971 500L, left hand drive.
- anyone have an easy solution to replacement of the rivet in the window frame hinge?
I hate do-overs!
I hate do-overs!
