are the hubs of the brakes on a standard uno different from the turbo ones, for example if i get the turbo size discs will the calipers fit fine or will it not due to bigger discs?
Dale
I'm fairly sure the hubs on the turbo are different from the standard Uno. I think they're bigger, plus don't forget the driveshafts are unique to the turbo too.
Turbo discs are thicker because they're vented (standard Uno discs are solid). Standard calipers will NOT work with turbo discs as they're not wide enough, plus the the turbo calipers are of a slightly different design as they use sliding pins instead of sliding wedges.
