Technical Uno 1100 Clutch bleed
Mauricej41
Guys what's the best way to bleed my clutch after fitting brand new Master and Slave cylinder on Uno 1100?
I find if a problem vehicle trying to bleed, whether clutch or brake, sometimes just removing the bleeder and keep topping the fluid reservoir until fluid is clear of air then refit bleeder can work in extreme cases, without touching the pedal.
Normally just opening bleeder, depress pedal tighten bleeder release pedal etc. Failing that one of the pressure bleeder kits available.:)
