When I removed the selector linkage rods at the gearbox end some time ago, I remember manually moving the gear selector leavers on the gearbox. Before removing the box, I could engage all gears.
There are two leavers:- one moves the other up and down, this other moves left to right to select gears at different heights.
When I was manually moving the leavers, the left to right leaver locked in place. I assumed it had engaged into a gear, and would sort it’s self when refitted. I’m not so sure now.
I have since purchased a MK1 box, which has turned out to be a duffer, but it made me realise that I don’t need to swop sub frames to convert from a bottom shift to a top shift gearbox.
Having removed the slave cylinder from the MK2 box, I cleaned and fitted the MK1 clutch fork to the MK2 box last night.
I then compare the selector leavers. On the MK1 they both move freely, clicking in and out of gear, but the MK2 is frozen.
My question is…
Is it sounding like the MK2 box is stuck in gear? Is there anything I can do inside the box to check or free it off? I’ve not missed something like a reverse inhibitor or something silly (don’t think the MK2 UT box has one)?
My question is…
