Technical Uno turbo mk2 power bump
Sotogun
Greece
Hi lads,
I need some advice. I want to know what should i tweak/ upgrade in order to make my uno produce around 150bhp (safe) without ruinin the OEM+ theme. My engine code is 146.A8.046.
Any thoughts?
s130
Moderator
Staff member
Wrexham, North Wales
OP
OP
S
Sotogun
Greece
s130
Moderator
Staff member
mine has +114hp from factory.
That is +8.6% call it 10%. You are looking for 4 times that!
On naturally aspirated engines then +10% could be achieve with fitting free flow exhaust, better air filtration, carb jet increases and some other tinkering. Power gains on turbo engines were far more achievable with simple boost pressure changes BUT when one starts to increase boost pressure then there comes a point where more radical changes are required if you don't want to blow your engine up.
You could try a simple Nitrous Oxide injection system. None of the Mad Max stuff. NO can radically increase engine power with a MTBF (mean time to failure) of seconds if you go mad. :)
