Hi all, again.
Car now starts fine every time, first time
The new issue (an old issue that appears to have gotten worse)
When coming to a stop, clutch & brake pedals down, engine sounds a bit odd, like its stalling when clutch is still on and stopping and the same time.
Except the car still moves without the shaking you would get etc.
the car then stalls. (Clutch pedal to the floor, out of gear)
This problem is an on / off problem.
Most likely, although differcult to tell, when the pedals are pressed brake then clutch rather than clutch then brake. (BTW - were talking milliseconds here not hours between brake & clutch)
This problem is only at low speed, when stopping in either 1st or 2nd gear going less than 10 mph
Any ideas?
Cheers in advance
Any ideas?
Cheers in advance
