- Joined
- Jun 28, 2006
- Messages
- 719
- Points
- 123
I've got a problem with my mk1 Sei', it's developed a stutter around 2500 rpm when cold, this has been emphasized by a mckrich chip but it's still there under the standard ecu as well. This stutter goes away once the engine gets reasonably warm, but still below normal operating temp, mostly it's a single pause between 2400 and 2500 rpm but some times it'll show signs of the usual flat spot between 2000 and 2500 rpm but not always, and this only happens when the engine is cold.
There is an electrical problem with the car in that the battery light is on all the time and the battery slowly discharges over time, a known good alternator has been fitted and all earthing points have been cleaned up but to no effect on either the battery light or the stutter. I've swapped over a map sensor and a crank sensor without success, though the fact it didn't get better or worse tells me they're okay, this weekend I'll do a service with leads, plugs, fuel filter etc.
The flat spot problem doesn't bother me that much as it's a known issue but this 2400 to 2500 rpm pause is much more worrying, catch the engine wrong and some times it feels like the engine stalls for half a second or so. Does anyone have any bright ideas on what could cause this?
