- Joined
- Jul 9, 2009
- Messages
- 471
- Points
- 159
The X290 trip contains two "Service Mileage" displays, one for the basic Vehicle Service, and one for "Oil Change", which, on a vehicle with a DPF may be required out of sync with the main service.
Having had mine recently serviced, with both items carried out at the two year mark, I have doubts that the appropriate reset has been done (it requires two resets, one for each value).
Given the displayed values, I'm pretty sure about the overall service indicator not having been reset (it's value makes most sense as (almost) the residual mileage from current to 30k miles - the service interval).
The oil mileage value that is displayed, however, could logically either be the mileage at which the next change is required (which would mean it hadn't been reset), or the interval to the next change (as currently calculated, as it is variable), which would mean it had.
I have read what the manual says about the two values, but frankly, I don't trust it (given other errors in content).
Does anyone know from experience (or from interpreting their current values) whether:
...the trip-computer displayed values for "service" are mileage at which the service is required, or the interval to the next service, and
...the trip-computer displayed values for "Oil service" are mileage at which the oil-change is required, or the interval to the next oil-change?
(AIUI, not resetting the Service Mileage is simply an annoyance, with any warning message generated in the future eventually disappearing, but the Oil-Change mileage will generate a warning which, if ignored, will ultimately cause the vehicle to drop into 'limp mode').
