B Briski 19 New member Joined Aug 6, 2019 Messages 1 Points 1 Aug 6, 2019 #1 I have a knocking sound and a wobble when when accelerating through the gears that is getting progressively worse, tyres and steering are fine and engine mounts are fine. Any ideas?
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 35,007 Points 7,842 Location Near the M4 Aug 8, 2019 #2 Hi. Bob weight on the driveshaft..? Standard test.. dip clutch.. does it change tone ? Constant is drivetrain Altering is motor ( clutch and flywheel) Does it do the DMF Chirp on shut.down? Charlie Last edited: Aug 8, 2019
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,294 Aug 11, 2019 #3 Do you mean steering wobble or engine shake? Steering wobble can be caused by the wrong wheels (too much offset) or worn bottom arm bushes. Another option is a buckled wheel. The vibration will be worst at 50 to 60mph but virtually gone at 80mph.
L leelister6 New member Joined Sep 29, 2016 Messages 1 Points 0 Sep 23, 2019 #4 Mine was nearside drive shaft
