Technical wishbone bolt
hi
I'm having a bit of trouble replacing a passenger side wishbone on my 53 plate punto 1.2 active . Ive snapped the rear bolt trying to get it off , is this a captive nut in the sub frame ?.
Looks like captive nut on chassis.
Hopefully you can gain access without too much carpet hassle....
Btw, I soaked mine repeatedly in release oil for a long time. Didn't help, still had to use a breaker bar and cross the fingers. Blowtorch if I ever do it again.
I think those are high tensile bolts, remember fit same strength one back. It's fine pitch too iirc.
i don't mind lifting the carpet , for a while i was thinking the sub frame had to be dropped, pure nightmare ,
yeah i done the same loads of penetrating oil , no joy , should have worked it back and forth slowly
yes ill get the bolt from the stealer's, be on the safe side
so I'm hoping its a case of measuring dead on, cutting a hole in the floor pan and the captive nut will be at the top of the sub frame
yeah ziggy , need to get myself some copper grease
i blame scotty kilmer he made it look easy , he changed a wishbone in 3 min lol
That american dude thats hell annoying on youtube?
Eric the car guy FTW!!
I didn't find that the bolts were very rusty, surprisingly.
I did go back and forth a bit, this always helps clear the rust out the threads.
I agree - rock it
I did that on the rear stub axle nuts, my god they were on fire afterwards tho!!!
Ziggy
How did you fix it? I'm having the same issue, the bolt just spins..
Removed the carpet but i think i need to cut the metal floor?
Video: https://imgur.com/GZen0E3
Picture under carpet: https://imgur.com/WV4c39d
Or if anyone else has the answer i would be really thankful.
the captive nut is on the subframe
Thanks judderbar :) I recently just noticed myself trying to squeeze a wrench inside to grip the nut.
What do you suggest i do? Remove the whole subframe and weld the nut back? If thats the case, do i need to hold up the engine?
Personally I would want to avoid removing the subframe if there was an alternative way - even when I know I have good bolts that are going to come out easily.
If you drill upwards thru the damaged nut and then enlarge the top newly drilled hole inside the car to fit the nut over the lower newly drilled hole you could probably tighten the wishbone bolt sufficiently to compress the first layer of plate under the car down onto the subframe using a longer bolt of the same strength. The strength of the bolts are marked so you can get a replacement from an engineering shop.
On the other hand, to get the subframe out with minimal work.............
Better to support the engine, but the dogbone only stops the engine from rotating when you are driving.
Potentially if you remove the top nut off the strut inside the engine compartment, take the sliding pins out of the caliper as if you were changing the front brake pads and support the removed calipers, unclip the ABS cables from the subframe, undo the pinch bolt holding the steering rack to the column, release the petrol and pipes from the plastic pipe on the subframe you might be able to rotate the subframe sufficiently to get at the nut without taking the struts off the hubs and disconnecting the drive shafts.
If you make a good job of drilling out the nut I cannot see why you cannot just fit the nut inside and compress it all down. No worries that come to mind at the moment.
If you drill upwards thru the damaged nut and then enlarge the top hole inside the car to fit the nut over the lower plate you could probably tighten the wishbone bolt sufficiently to compress the first layer of plate under the car down onto the subframe.
I see what you're saying.
Does the captive nut need to be welded onto the subframe? I'm thinking if i just unbolt the subframe a bit, like an inch so it drops a bit, i can possibly get a wrench inside to hold the nut while i undo the bolt. Then just replace wishbone.
just wondering if the nut has to be welded for structural integrity or something, i dunno :)
Thanks.
Thanks.
So drilling the nut out correctly from below is impossible. There is no way to get the drill to correctly go thru the wishbone and through the middle of the nut. :(
Next problem is the captive nut is in a recessed hole. I am imagining grips at an angle will be a challenge and the weld will cause the nut to tear using a socket. The captive nut welding is just for convenience.
It is not difficult to lower the subframe if you can support the car safely. You just need to make sure you work the bolts out gently with plenty of back and forth to break them free of the rust. Give it a bit of muscle to undo and then the other direction with the same power rather than trying to break them free with all of your strength, and just keep repeating this. Eventually the bolt will break free from the rust.
Yup kinda tricky but might work. Yes i went back and forth on the other bolts and they seem ok ?
I dont need to weld the nut right? If i can torque it correctly
Just saw this, thanks :)
Successfully lowered the subframe enough to get a ratchet + socket to fit the nut :)
Replaced both wishbones, however the nut and bolt that i had a problem with stripped when i was going to bolt it in at 110 NM torque.
Now i need to search for a replacement bolt and nut. Any suggestions? Read about it needing a tensile grade of 10.9.
