Driving on at 12⁰C atmospheric temperature, engine heating up goes like this:
I will post a follow up here, although this thread name is completely different. Anyhow, things are all related so, considering my previous mentions about engine heating up timings I think I can continue here on that.
Turns out the thermostat was faulty earlier. Needle shouldn't move down on the gauge once it gets to working temperature. The middle line corresponds to a range of degrees, it's not for a single number. The needle hits the middle line at 80⁰C and stay there at 94⁰ too, probably a little more above 94. My previous temperature monitoring was wrong because I based it on the gauge and didn't have the exact temperature. The thermostat's internal gasket was damaged there so it couldn't close completely anymore. The engine ran actually at temperatures between 70-80⁰C there, or so, underheated anyway.
So needle moving down, under the middle line is a clear indicator the thermostat is faulty, it can't close enough.
This is a graphic of actual temperature. It clearly shows engine doesn't get hot enough. And I could see that when I turned on the heat (and the heater fan blew on the heater matrix) the temperature would drop actually, which shouldn't happen.
The thermostat
It's quite very ingenious thing the thermostat, how it works.
And there are endless discussions coming from the question if thermostat should close completely or not. It's really up to the maker that. There are some that does close completely and others that have a little breather that allows a very small flow.
I had one Calorstat by Vernet (TH5069.87J) thermostat in use, the internal gasket failed on it and it wouldn't close completely anymore. This one has a breather, you can see it in the picture. It is very small.
The space in the middle in the first pic is where the gasket sits. It broke on this one, I got a little part coming out of the radiator breather when I bled the system after putting new thermostat in. I shall get the radiator down in the spring and get the rest of it out, also clean it on the inside.
I got a Thermotec (D2F008TT) thermostat now. There is no breather on this one, so it does close completely. I blew into it to test it and the air didn't pass through. Here it shows the gasket, I'm just sorry I didn't take a pic of inside pipe as this is a little bit different and can't find a pic on the internet.
So the engine heats up quickly than my previous observed timing. It gets to working temperature in 7 mins, driving 2.7 km. And the temp doesn't go below 87⁰C once it gets there, no matter how fast the car goes and how cold is the air hitting the radiator. Here is a graphic of it.
And a little note here. This thermostat closing completely, it wouldn't bleed completely when cold. And on the first ride, having a little bit of air in the system, the temperature would drop to 84⁰C. So that's an indicator, a very good one. If temp drops below 87⁰C while driving, there is air in the system. Once heated up I could easily bleed it and temp stays 87⁰C minimum afterwards.
And here are some pics with the main character, the thermostat, here missing its gasket. And this is how it works, the ingenious principle. When I put it in hot water the little shaft in the middle of it came out. And it wouldn't go in if I pressed on it. When it got colder and I pressed it, it did go in.
